Imagine a lathe with a rotating tool. The axis of the
rotating tool will be called A and the position is
measured in degrees.
(I know this is contrived, but the actual machine is
harder to describe/understand)
Z is the axis of rotation of the workpiece, +X is towards
the operator. Assume all distance units are inches
A typical threading operation would look something like
G0 X.5 Z0
G32
G1 Z5 F.1
This would give us a 10TPI thread.
But now I want the cutter to rotate 10 revs per rev of the
workpiece. In 5 inches of threading we get 50 revs of the
workpiece, hence 500 revs of the cutter, so we get something
like
G0 X.5 Z0 A0
G32
G1 Z5 A500 F???
And that's the question - what's the feed per rev for the G1
command? Do we treat the A and Z axis units as if they are
comparable Cartesian units and set the speed to sqrt(A*A +
Z*Z) = sqrt(10 * 10 + .1 * .1) = 10.0005?
When the A distance is large compared to Z (imagine we want
500 revs/rev), do we just ignore the Z part of the
computation because it's so far down in the noise?
